机械密封英文外贸词汇
这里列出了34个机械密封分类术语,仅供各位网友参考...
1.机械端面密封-mechanical face seal
2.流体动压式机械密封-hydrodynamic mechanical seal
3.切向作用流体动压式机械密封-tangential acting hydrodynamic mechanical seal
4.径向作用流体动压式机械密封-radial acting hydrodynamic mechanical seal
5.流体静压式机械密封-hydrostatic mechanical seal
6.外加压流体静压式机械密封-outside pressurized hydrostatic mechanical seal
7.自加压流体静压式机械密封-self pressurized hydrostatic mechanical seal
8.非接触式密封-non contacting (free contacting) mechanical seal
9.内装式机械密封-internally mounted mechanical seal
10.外装式机械密封-externally mounted mechanical seal
11.弹簧内置式机械密封-mechanical seal with inside mounted spring
12.弹簧外置式机械密封-mechanical seal with outside mounted spring
13.背面高压式机械密封-mecanical seal with high back pressure
14.背面低压式机械密封-mechanical seal with low back pressure
15.内流式机械密封-mechanical seal with inward leakage
16.外流式机械密封-mechanical seal with outward leakage
17.弹簧旋转式机械密封-spring rotating mechanical seal
18.弹簧静止式机械密封-spring standing mechanical seal
19.单弹簧式机械密封-single-spring mechanical seal
20.多弹簧式机械密封-multiple-spring mechanical seal
21.非平衡式机械密封-unbalanced mechanical seal
22.平衡式机械密封-balanced mechanical seal
23.单端面机械密封-single mechanical seal
24.双端面机械密封-double mechanical seal
25.轴向双端机械密封-axial double mechanical seal
26.径向双端面机械密封-radial double mechanical seal
27.串联机械密封-tandem mechanical seal
28.橡胶波纹管机械密封-rubber-bellows mechanical seal
29.聚四氟乙烯波纹管机械密封-PTFE-bellows mechanical seal
